idler arm check
Old Feb 22, 2018 | 11:39 PM
puttster's Avatar
Default idler arm check
Is there a good way to check if the idler arm is doing/not doing its job? I'm wondering if that's the thing doing all the rat-tat-tat-tating?
Old Feb 23, 2018 | 07:49 AM
Logan's Avatar
Logan is on a distinguished road
Get someone to turn the wheel side to side while someone looks under the vehicle at it. I usually hold it while someone turns the wheel side to side. Then you can feel if there is play.
Old Feb 23, 2018 | 11:58 AM
It should only (well mostly) swing in an arc with no up-down motion.
Old Feb 24, 2018 | 02:41 AM
odat's Avatar
With enough slack in the idler arm to rattle you prob would have a problem with the vehicle wandering and ducking and diving while driving down the road.
Old Feb 25, 2018 | 08:16 PM
I actually made a video about this a while back they 2nd time I changed mine on my 04
Old Feb 26, 2018 | 12:45 AM
Nice video.
When I replaced my idler arm, I could get much more deflection (vertical) than you did with both tires off the ground which would indicate just how loose it was.
There are two good replacement idler arms; Proforge and Moog. Did you use the Moog part?
There is also a way to adapt a 1-ton truck idler arm to a Blazer. The adapter cost $200 though! However, if the last idler arm fails, I'll likely go for the 1-ton upgraded one.
P.S. Dude, your undercarriage is spotless! I wish mine when clean looked as good as your when "dirty". LOL
Old May 9, 2018 | 04:56 PM
puttster's Avatar
Blazin, sorry I did not see this and thank you for it.. I think I have more deflection than you did but the steering is pretty steady so maybe not, I'll check it out.
I don't think that is causing the bonka-bonka-bonka-bonka when I drive over a rough street, though, do you? But if it moves like you say it probably needs replacing
Old Aug 25, 2018 | 02:57 PM
puttster's Avatar
On edit, I went ahead and replaced the idler arm and will write how the operation went in another post. The bonka-bonka turned out to be a loose hood hinge bolt.
orbitalcircle
Jun 14, 2015 02:48 PM
Heather Berg
Aug 14, 2012 06:58 PM
cartunez2004
Apr 9, 2011 09:01 PM
danyboy
Apr 5, 2009 10:25 AM
RedOctober
Oct 11, 2006 09:00 PM
