idler arm of death
Old Jan 20, 2015 | 08:14 AM
habafab's Avatar
habafab is on a distinguished road
Default idler arm of death
So i have had my 98 2 door for about 2 years now and i have replaced the idler arm 28 times (yes about once a month)( and iv had every brand known they all go around the 1 month mark) i have changed EVERYTHING in the front end had it aligned everything, i switched it back to stock height and stock tires still blows them at the same rate, iv avoided potholes off roading everything you can think of yet idler arms still blow like no tomorrow, any ideas on a fix? Thanks for the help cause even my local chevy dealer hasnt the slightest clue
Old Jan 20, 2015 | 09:42 AM
rexmburns's Avatar
Super Moderator
Look into the 1 ton idler upgrade you can buy a kit from synergy off-road. It's not cheap but it will fix your problem.
Old Jan 20, 2015 | 06:37 PM
habafab's Avatar
Awesome do you know what the kits called like what its off of?
Old Jan 20, 2015 | 06:43 PM
rexmburns's Avatar
Super Moderator
Old Jan 20, 2015 | 06:54 PM
habafab's Avatar
Your awesome. I thoight about putting a steering stabilizer on it to hopefully help thoughts?
Old Jan 20, 2015 | 07:12 PM
Blazin_Jason's Avatar
Stabilizer shouldn't hurt, but I doubt it would help save the idler at all. I'm planning on ordering the bracket at some point as well.
Old Jan 28, 2015 | 10:45 AM
TZFBird's Avatar
TZFBird is on a distinguished road
If you want to hold off buying a bracket, I'm building one and should have it done in a month or two and can let you know how it works. I'll be more than happy to send you the dimensions if you want to try to make one yourself (once I figure out if the design is safe and reliable). For what they are, they seem a bit overpriced. So far I have about 3 hours invested in it between doing the math for dimensions as well as some cutting and welding of materials. It's not close to done yet but it's started at least.
Old Feb 1, 2015 | 01:19 PM
div's Avatar
div
div is on a distinguished road
I agree. I'd love to have one but $370 for chunk of steel, that is just ridiculous.
Old Feb 27, 2015 | 03:47 PM
DTS77's Avatar
DTS77 is on a distinguished road
im also having this problem and if you didnt mind when you figured it out for yourself i have a friend whos a welder and would greatly appreciate you sending me specs as well if you didnt mind
Old Mar 3, 2015 | 09:41 AM
TZFBird's Avatar
I've been working on house projects lately since it's still pretty cold here. Temps should start coming up in the next couple weeks so hopfully I can get to it. I look at the bracket every day on my toolbox so it's not forgotten. I'm just not a fan of laying on concrete that is below freezing if I don't absolutely have to.
It is on my warm weather list along with repairing the window regulator and troubleshooting the fuel system.
