idler arm/pitman arm install?
Old Aug 16, 2007 | 02:58 PM
GMdesigner's Avatar
GMdesigner is an unknown quantity at this point
Default idler arm/pitman arm install?
hey guys, tried to get my truck alligned recently after adding my 31"s, and the shop said they wouldn't do it because my ball joints were wasted, and they also said that I needed an idler arm and a pitman arm as they were shot. I do have a lot of slop in the steering. I am going to do the ball joints myself, but wanted to know how hard you think it is to do the idler arm and pitman arm. Any thoughts?
Nick
Old Aug 16, 2007 | 03:56 PM
Default RE: idler arm/pitman arm install?
The idler arm isn't all that bad, but then again I have an air hammer with a pickle-fork attachment! The pitman arm will require a pitman arm puller to remove. While you are at it, check the tierod ends. If there is ANY doubt, change them as well. An alignment is $60-80 whether you replace them or not. It never fails that whenever I have replaced a steering component, something else in the steering went bad within a month requiring another alignment...
Old Aug 23, 2007 | 02:08 PM
thegr81's Avatar
thats true swartlkk anytime you go to replace a steering component check all of them just replacing one might mean haveing to do all of them cause there soon to follow in needing to be replaced if there is a significant amount of slop in the steering check your steering box on the frame that might need tending to as well.
Old Aug 23, 2007 | 04:57 PM
The way I look at it is this... It's $60+ for an alignment. Why have to pay that more than once.
wild bill
Dec 25, 2010 02:02 PM
greatwhite
Nov 28, 2010 11:54 PM
88s10Blazer
Dec 24, 2009 08:43 PM
kornphlake
Dec 18, 2006 02:18 AM
RedOctober
Oct 11, 2006 09:00 PM
