is it idler or pitman?
Old Jun 30, 2012 | 02:23 PM
Heather Berg's Avatar
Heather Berg is on a distinguished road
Default is it idler or pitman?
i have wear on the inside of my driver tire and when i jacked it up i can wiggle the passenger tire side to side. this is my first blazer and i know nothing. there is an arm attached to the tie rod and it is bouncing up and down. the arm is on the passenger side. i was told this is the idler arm and i was told it was a pitman arm. i just changed my brake pads for the first time and noticed all this. can anyone help me?
Old Jun 30, 2012 | 02:57 PM
50lb_cat's Avatar
If it wiggles a lot side to side it usually meens the wheel hubs are bad. The idler arm is on the passenger side and the pitman arm is on the drivers side. The idler is easy to get to after you remove the plastic skid plate. It bolts to the frame and the centerlink. The pitman is a real PITA If you have a 4x4. You have to remove the steering box and use a pitman puller.
serrasalmus's Avatar
serrasalmus is on a distinguished road
DRIVER SIDE IS PITMAN ARM AND PASSANGER SIDE IS IDLER ARM oops caps and im to lzy to retype it
Old Aug 14, 2012 | 06:58 PM
Manatee's Avatar
Manatee is on a distinguished road
I just bought an idler arm at NAPA about 2 hours ago $45. Will install it later this week.
kerander
May 25, 2008 10:48 PM
GMdesigner
Aug 23, 2007 04:57 PM
kornphlake
Dec 18, 2006 02:18 AM
RedOctober
Oct 11, 2006 09:00 PM
alexbtango15
Suspension Tech
Jan 7, 2006 01:06 AM
