Labor time for pitman arm R&R?
Old Nov 4, 2015 | 05:09 PM
WalkGood's Avatar
WalkGood is on a distinguished road
Default Labor time for pitman arm R&R?
What's the labor time for Pitman arm replacement on 98 Blazer 4x4?
I've googled but did not find. Some posts suggest the steering gear box must be completely removed. Others state the box just needs to be unbolted but only twisted around to remove pitman arm.
I'm gonna bring mine to a shop, as it looks like big PITA replacing while lying on my back.
Old Nov 5, 2015 | 09:27 PM
slimsummers's Avatar
slimsummers is on a distinguished road
No idea what the book rate is, but on my 95 I just unbolted the box and moved it around to get at the pitman arm with the puller. Took a little less than an hour. This was on a lift at the shop using power tools, flat backing it would not be something I would try either...
Old Nov 6, 2015 | 06:15 AM
Groundunit's Avatar
Groundunit is on a distinguished road
If you have power tools I think it is possible to just twist it around without having to pull out the steering box. But if you're me, without power tools, you will have to pull the sucker out. It took about 2 hours to replace mine after I pulled it a second time. I had to put mine in a vice to remove the pitman arm with a puller.
Old Nov 6, 2015 | 07:13 AM
lazyboyjake's Avatar
lazyboyjake is on a distinguished road
According to alldatapro 1.3 without a skid plate and 1.7 with a skid plate. I'm not sure why the skid plate makes such a difference but somewhere around 1-1.5 hours should be your typical time to replace.
Old Nov 7, 2015 | 05:56 AM
newguy's Avatar
Can be PIA to get the pitman nut off. I used a cutoff wheel and cut through the nut then had to use a chisel to spread the nut just to get it off
Old Nov 7, 2015 | 07:47 AM
WalkGood's Avatar
Is that labor time for a 98 4x4?
I've got a plastic cover, wouldn't really call it a skid plate.
Old Nov 7, 2015 | 08:01 AM
abig84's Avatar
its gonna suck without a impact. most the older chevys i deal with have very rusty power steering lines so you always risk breaking those by taking them off
but that plastic cover isnt that big of a deal, 4 or 5 bolts
WalkGood
13
Dec 7, 2017 12:39 PM
88s10Blazer
Dec 24, 2009 08:43 PM
GMdesigner
Aug 23, 2007 04:57 PM
kornphlake
Dec 18, 2006 02:18 AM
RedOctober
Oct 11, 2006 09:00 PM
