Leaf Spring?
Old Nov 9, 2016 | 04:45 PM
Jimmy_Blazer's Avatar
Jimmy_Blazer is on a distinguished road
Default Leaf Spring?
Recently acquired a 99 4 door Blazer with jeep wrangler axles under it. One of the leaf springs on the back is cracked and needs replaced. Only Problem is I don't know what kind they are or what they're from, as they are definitely not stock blazer ones. There are 5 leafs on them and no overload spring, not sure on the lift of them. If I know what to look for I could be more descriptive so I can get an answer.
Old Nov 9, 2016 | 09:39 PM
abig84's Avatar
post some pictures we might be able to tell. or bring them to your local spring shop if you have one and they can just fix the few broken ones
Old Nov 11, 2016 | 10:18 AM
Hope these will do? Don't have a spring shop anywhere near me.
Attached Thumbnails Leaf Spring?-p_20161111_110914%5B1%5D.jpg   Leaf Spring?-p_20161111_110929%5B1%5D.jpg   Leaf Spring?-p_20161111_110946%5B1%5D.jpg
Old Nov 12, 2016 | 03:37 AM
newguy's Avatar
Try to find 2 similar and replace both sides
Old Nov 12, 2016 | 09:06 AM
Yes that's what I plan on doing. Is there a way I can search for leafs that have the same dimensions as the ones on it?
Old Nov 12, 2016 | 02:52 PM
newguy's Avatar
Take some measurements
Old Nov 12, 2016 | 07:35 PM
Obviously. Now how do I use that information to search for similar springs? Every leaf pack I find just gives a compatibility list of vehicles, not dimensions.
Old Nov 13, 2016 | 02:30 AM
newguy's Avatar
Not sure, but maybe the junkyard, pick and pull would know
Old Nov 14, 2016 | 03:32 PM
The measurements I got for it is 54" with no weight, and the perch pin is right in the middle at 27". It's 2 inches thick and has 5 leafs. From what you can see in the photos, the front of the leaf has a second leaf wrap around it (the eye with the bushing) as opposed to the rear where it is just the one. I really need to find out what its from or what kind of aftermarket it is if it is, been searching for 2 weeks now with no luck...
musclemasterflex
Suspension Tech
Aug 26, 2011 09:10 AM
musclecar70sfan
27
Jan 19, 2010 04:10 PM
86 like me
Suspension Tech
Sep 22, 2008 07:59 AM
mr.vls
Apr 3, 2008 10:48 AM
myronhntr80
Lifting Tech
Jan 6, 2008 11:29 PM
