Leaf spring swap
Old Aug 11, 2015 | 10:50 PM
jatkins3983's Avatar
jatkins3983 is on a distinguished road
Default Leaf spring swap
I need a little help here with a suspension issue. My leaf springs are sagging really badly on my 1999 LS 4X4 4dr blazer. I use this vehicle to tow a trailer for work and I need something for more rear end lift it is way too low. I already have coil over shocks on the rear but they are useless with the bad springs. I want to replace the leaf springs but I'm not sure what to put on instead of factory. Can I fit zr2 leafs or a larger set from like a Silverado? And if it is possible to make a larger set fit what mods are required for it fit and perform
Old Aug 12, 2015 | 08:40 AM
rexmburns's Avatar
Super Moderator
Check out Generalspring.com they have the best listing of springs to use for cross reference to see what else might work. I'd suggest getting a set of the z85 optioned springs and if those aren't enough add a helper leaf as well.
Old Aug 12, 2015 | 02:54 PM
Sounds cool man. Thanks brother if I can cross reference I can find some junk yard ones
Old Aug 12, 2015 | 08:27 PM
When you mean z85 option how should I look this up. I know the blazer springs are smaller than Silverado. Can the larger ones be bent into the original space
Old Aug 12, 2015 | 10:10 PM
rexmburns's Avatar
Super Moderator
Z85 was the "heavy duty" suspension option for blazers. No you can't been longer springs into place.
Old Aug 13, 2015 | 11:57 AM
Your friend told me you could put bigger springs in the time like I don't understand how that's supposed to work I did call around to a couple of the auto salvage yards and they were telling me the z85 Springs for the Blazer only fit on the two door model does that make any sense
musclemasterflex
Suspension Tech
Aug 26, 2011 09:10 AM
musclecar70sfan
27
Jan 19, 2010 04:10 PM
86 like me
Suspension Tech
Sep 22, 2008 07:59 AM
mr.vls
Apr 3, 2008 10:48 AM
myronhntr80
Lifting Tech
Jan 6, 2008 11:29 PM
