leaking front axle
Old Jan 18, 2009 | 04:33 PM
DJ 4x4's Avatar
DJ 4x4 is an unknown quantity at this point
Default leaking front axle
I have a good bit of oil leaking from my front axle around where it connects into the tube that then goes into the front diff. It seems to have sprayed oil in a circle from it turning. Question is what is it thats leaking (a seal of some sort). Also how hard is it to change.
Ill get some pics of it shortly.
Old Jan 18, 2009 | 04:45 PM
Default RE: leaking front axle
Is it green? If so, you blew a CV boot. If not, it could just be the lip seal on the passenger side extension tube.
Old Jan 18, 2009 | 05:48 PM
DJ 4x4's Avatar
no its not green, all my boots are good. i think its the lip seal how hard is that to replace its getting kinda bad.
Old Jan 18, 2009 | 07:25 PM
Getting the CV shaft out is the difficult part. You have to pop a ball joint loose to get enough room to get the CV shaft room to pull out of the axle tube. You will also need a good peice of wood and a 5lb hammer to get the shaft out of the axle tube. Once the CV shaft is out of the way, it is not too difficult.
chowell
Mar 6, 2021 09:47 PM
blajeans
Jan 9, 2013 12:58 PM
haha29
Dec 28, 2010 07:41 PM
rebelchevy
Jan 23, 2010 05:56 PM
flyinbrad
Dec 4, 2007 02:51 PM
