Leveling ZR2 suspension?
Old Dec 11, 2017 | 11:40 PM
Blazer_YYC's Avatar
Blazer_YYC is on a distinguished road
Default Leveling ZR2 suspension?
Hey guys, I have a 2005 ZR2 and I am trying to get the vehicle to sit level. Right now my measurements from ground to the bottom of the fender flare are 36" in the front and 34" in the rear. I have tried adjusting the torsion bars but after backing the bolts completely off it has not moved. I am thinking since it has 200,000KM (125,000 miles) on it that maybe it is time for new struts. Do you guys think new struts would bring the back end back up? Should I replace the leaf springs as well? I'm new to the 4x4 and I'm not sure when leaf springs need replacing.
Thanks
Alex
Old Dec 12, 2017 | 05:39 AM
chevyriders's Avatar
New shocks won't lift the back of the truck(save for air shocks). Your leaf springs are probably sagging. Replacing them would be your fix. With 125k miles replacing shocks would probably be in order too.
Springs support your weight, shocks dampen the rebound from the action of the spring.
S series trucks don't have struts
Old Dec 12, 2017 | 06:16 PM
AJBert's Avatar
Or get some 2 inch longer shackles.
Old Dec 12, 2017 | 09:01 PM
Strangerock's Avatar
Strangerock is on a distinguished road
I just might have the shackles you need , I just have to come up with a price , they are 2 and 3 inch lift shackles brand new ....and I'm in Calgary ...which I believe you are also....You would have to pick up bolts as they did not come with.
Old Dec 13, 2017 | 02:59 AM
newguy's Avatar
Or an add a leaf will put a bit of life back in the leafs and give you lift also
Old Dec 14, 2017 | 08:56 AM
El_Beautor's Avatar
Personally I don't think shackles is the best option if the suspension is sagging. All you're doing is masking the problem of a tired suspension. I think either additional support to help the saggy leaf pack, or replacement is the better option.
If you find the ride to be soft, I'd second the suggestion of either an add-a-leaf. The saggy back-end is the back suspension just being tired. It's pretty common. I have a parts ZR2 with the same issue. If you decide to go with an add-a-leaf I'd suggest making your own by grabbing the main leaf from a leaf pack from somewhere like a pick-n-pull. Take the main leave and cut off the eyes so that the add-a-leaf is just shorter than your main leaf. This will give support for the full length and will lift the back end and firm up the ride (starting to sound like plastic surgery here). You'll probably end up with a bit stiffer ride that original. Some people (myself included) prefer a stiffer ride in a 4x4.
Going with a shorter add-a-leaf will work too, but the problem is that your main leaf may end up starting to reverse-curve into an "M" shape if it is very worn out. This is far from ideal.
The other option would be to replace the leaf pack entirely. This will also lift the back end back to factory height, while maintaining the factory ride. If you like how your Blazer rides now, this may be the best option.
Old Dec 16, 2017 | 09:12 AM
Blazer_YYC's Avatar
Hey guys, sorry ti has taken me awhile to respond. I think I'm going to replace the leaf springs and all the struts and hopefully that should take care of it. Because at that point the entire suspension system in the front and back will be brand new! I'm thinking with 200K its probably time to replace the struts anyways. Any suggestions? I want to have the best ride quality I can get. I won't be doing much off roading in this thing anytime soon if ever, its my winter cruiser/second vehicle.
Thanks guys
Alex
Old Dec 16, 2017 | 03:51 PM
AJBert's Avatar
By struts are you meaning shocks? These vehicles have no struts but they do have shocks.
Old Dec 16, 2017 | 03:52 PM
Blazer_YYC's Avatar
Yeah I mean Shocks
Old Dec 16, 2017 | 06:17 PM
Blazer_YYC's Avatar
My goal is just to get this thing level and have a nice smooth ride. Let me know if you have any suggestions for a good quality riding shock for front and back.
rickmfromnh
Aug 15, 2011 07:30 PM
grensha2
Suspension Tech
Dec 23, 2010 04:24 PM
dieseldyr
Jun 2, 2010 08:28 AM
NYBLAZER
May 10, 2010 01:22 AM
Rp9110
Jan 5, 2008 11:27 PM
