Lifting 2001 gmc jimmy
Old Jun 19, 2008 | 02:23 PM
fishinhunter12391's Avatar
fishinhunter12391 is an unknown quantity at this point
Default Lifting 2001 gmc jimmy
hey lookin to lift my 2001 gmc jimmy 4x4 up 2-3". Im not sure which way to go with this as far as how to lift it. http://www.4wheelparts.com/Lift-Kits...p;t_pn=SUPK451
I'm lookin into something like this but i have heard this really wears on your front end. I really dont know where to start so any help or advise on a lift is appriciated. thanks Tyler
Old Jun 19, 2008 | 06:57 PM
_97Jimmy_'s Avatar
_97Jimmy_ is an unknown quantity at this point
Default RE: Lifting 2001 gmc jimmy
this is the site with lots of info about our type of vehicles, if your looking for 2-3 inch lift ideas just check out the nifty search button, type in 'lift kits' or 'lifting issues' and lots of great info will pop up, thats what i do. I had all my questions about lifting answered without even posting, it was great
Old Jun 19, 2008 | 11:33 PM
ive looked through many. no i dint look through them all but seem like they were related directly to a certain lift. not what im asking.
Old Jun 20, 2008 | 06:54 AM
I know this has been covered before, but...
That lift specifically only adds the benefit of correcting the steering upright angle when going to 2" lift via the torsion bars. This does little to correct the ball joint angle (what destroys ball joints) nor does it do anything to address harsh angles in the front driveshafts.
You can somewhat safely lift the front 1.5" with just a crank on the torsion bar bolts. If your torsion bars have gotten weak, then the keys may help you go further, but if you go all the way to 2", you might not like the outcome (both ride quality and repairs).
Old Jun 20, 2008 | 11:58 AM
What other ways are out there to lift the front? i see i could do an add a leaf or block lift in the rear. any imput on those
And did you mean with your last post that that 2" lift is or is not the way to go?
Old Jun 20, 2008 | 12:23 PM
riceh8r0512's Avatar
riceh8r0512 is an unknown quantity at this point
Shackles in the rear would be the cheapest way to lift it, you can go up 2" with those and it won't sacrifice ride quality, and you can even make your own https://blazerforum.com/m_99354/tm.htm
Old Jun 20, 2008 | 12:25 PM
WolfPack's Avatar
There are only a couple ways to do the front end on these trucks. Pretty much every 4x4 blazer you see lifted is either body lifted, or t-bar cranked. You'll be fine as long as you don't max it out, and as long as you keep an eye on the front end parts. Keep them lubed with every oil change, and watch your CV boots.
And adding blocks to the rear would actually lower the back end, as the leaf springs go under the axle. You can lift with blocks after you do a spring over axle conversion, but that flip alone gives you 5' of lift. Adding blocks only goes higher.
Just be aware of the potential risks, and you'll be fine
bdude273
Nov 22, 2013 08:30 PM
BigNeal
Performance & Brainstorming
May 22, 2012 11:43 AM
londonmazda
Oct 19, 2010 02:15 AM
don033189
Dec 9, 2009 06:52 PM
mhollis
Tires and Wheels
Jul 26, 2009 08:41 AM
