Locker options
Old Mar 15, 2011 | 11:25 PM
Benedict1337's Avatar
Pulled it out of a bravada in the junk yard. And yea its as easy as removing the differential cover removing a small bolt attached to the middle pin removing the pin popping out the axles on each side and sliding the old diff out. Now putting the new one in you have to make sure you put the shims back in correctly in the bravada there was one on each side (not sure if they are all like that or not) and put the diff cover back on fill up on fluids and ur ready to go. Now "other parts" you mean...? If you are speaking of gearing if you buy a brand new diff they will not have a ring on them you wi have to take your ring off whatever is in there now and put it on the new diff. Now if you are like me and got a used one there may already be a ring on there. Just make sure that ring is the same gearing as what your truck originally has, and if noy you can remove that ring and put your existing one on the diff you want to put in.
Old Mar 16, 2011 | 06:54 PM
Zanders's Avatar
Zanders is on a distinguished road
all right thanks alot everyone, i'll get a rebuilt/new G80 and put my ring gear on it and drop it in.
Old Mar 20, 2011 | 01:29 AM
PaulO2288's Avatar
PaulO2288 is on a distinguished road
Benedict how did the g80 work compared to an open diff?
Old Mar 23, 2011 | 07:16 PM
BlazinAmazin's Avatar
BlazinAmazin is on a distinguished road
nope you can put any differential you want as long as its for the GM 7.6 10 bolt 28. The g80 is the differential, so if you have an open diff and want to put in a g80 you have to remove the open differential and put in the g80, or you have a g80 and want to put in a powertrax you remove the g80 and put in the powertrax
7.6? Thought it was a 7.5
Old Mar 23, 2011 | 08:01 PM
lol I haven't put mine in yet... and to be exact blazer axle size is 7.625" 28 spline
bigghoss
Apr 12, 2011 12:25 PM
walkingtall
Dec 27, 2006 10:48 PM
ceanern
Suspension Tech
Sep 20, 2006 12:56 PM
quontush
Aug 2, 2006 12:28 AM
96blazer
Aug 14, 2005 11:15 PM
