Looking For Suggestions, Front End Component Replacement
Old Dec 12, 2011 | 04:38 PM
OILCOUNTRY's Avatar
OILCOUNTRY is an unknown quantity at this point
Default Looking For Suggestions, Front End Component Replacement
Well I am going to be tearing apart my front end here soon and I am planning on replacing my Ball Joints/ Control Arm Bushings along with swapping out my torsion bars with a set of ZR2 T-Bars I just picked up. What else should I look at replacing while I have it all apart? Are there any bushing in/ Around the torsion bars? I Want to try and get it all out of the way in one shot. Any suggestions will be greatly appreciated.
Thank you,
Old Dec 12, 2011 | 05:51 PM
trucktom's Avatar
trucktom is on a distinguished road
no bushings for t bars. just shake it down and check hubs axle boots tie rods and idler pitman arm. and i would do all 4 balljoints when u have it apart there cheap. be carfeful with the torsion bars, read up on safe changing. i dont see a need to replace if not broken of totally sagged, they are adjustable ya know... set of front shocks never hurt either. and sway bar links if there busted of course. its not a bad job just be careful alot of tension releases when u undo the ball joints, put a jack under the lower control arm so u dont get a nasty scare i love this smiley!
Old Dec 17, 2011 | 04:05 PM
Joe Belchak's Avatar
Joe Belchak is on a distinguished road
Make sure you really tighten bolts that attach shocks, or you will hear every bump.
95BlackGA
Tires and Wheels
Mar 7, 2013 11:57 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
Gmas95
Sep 21, 2011 07:55 AM
jdub9000
Jan 9, 2011 01:14 PM
joethejman4us
May 25, 2009 12:26 PM
