loud knocking in 4wd
Old Nov 4, 2010 | 09:37 AM
audiboyv8's Avatar
audiboyv8 is on a distinguished road
Default loud knocking in 4wd
hi guys
I've been lucky enough to get given a 2000 chevy blazer and its great! The only problem is when I put it into 4x4 there is very loud knocking noise from the front which is worse the faster I go or when steering.
Its the 4 button type with auto 4wd. After reading through the posts here I have replaced the vacuum pipes and the electronic unit on the bulkhead.
So far no joy.
I have checked diaphram unit under battery and this appears ok and cable moves freely, if I apply vacuum manually to this diaphram its works the 4wd and its not as noisy in operation!
Today I jacked it up and had a look, there is a switch screwed into cable housing? at the front diff, it has a ball in the end which moves freely. might it be this??
My thoughts are that for some reason when I try for 4wd its only partially engaging? or front diff is damaged?
Any suggestions really appreciated as I'm stuck
Thanks
With car jacked up on stands all round and driven I am now confident the noise is coming from the transfer case, I remove filler/level plug on case and no fluid came out, so I stuck my finger in to see if any fluid, there was. Should it be red? I know it needs specific oil but its not easily available here.
Is it possible that when I try to go into 4wd that something is faulty and its half and half between 4hi and 4lo??
As its quite and faultless in 2wd!
Thanks
IanD
Jul 24, 2013 08:09 PM
mudman
Jul 24, 2013 07:57 PM
wildman1984
Jul 24, 2013 07:35 PM
chellebear187
Oct 15, 2010 06:50 AM
AppBlazer
Mar 6, 2010 06:05 AM
