Making nosie/clang when turning
Old Mar 1, 2009 | 11:09 PM
Stopphn's Avatar
Stopphn is an unknown quantity at this point
Default Making nosie/clang when turning
Good day all, I am having problems with a clang noise coming from the left side of my 01 blazer when I turn sharp and turning while in reversing (All a low speeds) I don’t hear the clang noise all the time. I replaced the upper, lower ball points and “cushion pins” I think that’s what they are called in Jan. I replace those items because I would hear a squeaking sound when I would go over bumps. ANY IDEAS ABOUT THIS CLANG NOISE WHEN I TURN AT LOW SPEEES?
Old Mar 2, 2009 | 12:35 AM
DJ 4x4's Avatar
DJ 4x4 is an unknown quantity at this point
Default RE: Making nosie/clang when turning
Ya i seem to have this same problem kinda seems like it happens when im pulling out of my drive way and i hit the brake to stop.I also hear it when im just pulling out of a parking stall. I also just had ball joints replaced. I also dont hear it all the time just some times. I cant seem to figure out what it is either andi just had my truck in the shop at a front end specialist when i had my ball joints done. They said my bearings and everything where good. Think it might be something to do with the axle shaft for the 4wd. If you figure it out please post back on here with what it was.
Old Mar 2, 2009 | 02:38 PM
Stopphn's Avatar
I was told that after you put new ball points in sometimes you have to lube themagain shortly after. He said for whatever reason you he had to grease a ball point two or three times before the clang noise went away. I don't know if there is any truth to that, but its worth a shot. I plan of going to the shop tomorrow and I will let you know what happens in a few days.
Old Mar 2, 2009 | 06:00 PM
DJ 4x4's Avatar
Hmm the guy that did mine didnt say anything about that i guess i could go check them out some time to see if they need some grease. And in regards to ur PM it happens in 2wd im not sure about 4wd might have to try and see if it does it in 4.
Old Apr 30, 2009 | 01:15 PM
blazinloud's Avatar
trying to figure out the same problem on mine. sounds like a rattling cat. converter, very very intermittent, but i DONT have a cat. converter.....seems to be coming from drivers front tire. but if i get out and push the suspension up and down it dosent make the sound.
makes that rattling type noise and very very bad sqeaking when going over bumps, turning and even going straight, replaced the brake pads a week ago, its not that. my wheels bearing dont humm or anything....anyone figure this out!? its sooooo annoying!
Old Apr 30, 2009 | 03:28 PM
okvortec's Avatar
This must me a pretty common problem.. my 01 does the same thing. drives me nuts.
Old May 7, 2009 | 06:40 PM
young murph's Avatar
young murph is on a distinguished road
i have a 2000 and i have that problem too. it makes noise when i turn slow or turn in reverse. i was thinking ball joints but i haven't had a chance to check them yet. could it be the steering box?
Old May 7, 2009 | 07:29 PM
1987 BlAzEr K-5's Avatar
1987 BlAzEr K-5 is on a distinguished road
could be cv's...but is very annoying!! someone figure it out!
Old May 8, 2009 | 08:02 PM
02 jimmy's Avatar
02 jimmy is on a distinguished road
My 02 Jimmy would make a clanging sound when turning sharp also, and at slow speeds, it turned out to be the front driveshaft was worn out, replaced it and never heard a sound again.
Old Apr 2, 2010 | 10:31 PM
jwhall3's Avatar
jwhall3 is on a distinguished road
I would love to know if anyone found out what was causing these problems. I have a 2000 Blazer that squeaks very loud anytime I go over a bump or turn and often when I turn hard while backing up or pulling forward slowly I hear a thud, such as pulling out of a parking place. Any help would be greatly appreciated. Thanks.
monette999
May 12, 2015 05:45 AM
rmcrowley87
Nov 11, 2013 04:31 PM
showboat
Aug 3, 2010 07:07 PM
blazer_in_ky
Nov 6, 2009 04:17 PM
bdscholes71`
Oct 7, 2007 02:59 PM
