manual hubs?
Old Nov 9, 2010 | 11:06 AM
nismo_2005's Avatar
nismo_2005 is on a distinguished road
Default manual hubs?
ok so we all know that the stock ifs on our trucks is not the most stout thing ever built. we also know that doing a tbar tweak adds more wear to our front end parts like cv shafts and bj's. well from everything i have read the upper arm kits like rough country can reduce bj angles and make them last longer.
so now to the cv shafts. wouldn't it be a good idea to add manual hubs like warns or superwinch? im not sure what the auto hubs on the s-series 4x4's are like cause the other dimes i have owned have been 2wd.
the way i see it is that by adding the hubs you could truly disco the front axles and add life to your cv's.
what is everyones opinion on this?
ok after a little more research i have found that this topic was a waste cause i did not realize that the s10 has a system similar to the chrysler cad axles. i thought it was actual vaccume hubs like on the isuzu rodeo as an example.
Old Nov 9, 2010 | 01:07 PM
Benedict1337's Avatar
yea there is no such thing as manual hubs for the s10s sadly... The only way to lift your truck without messing with the cv angles is either a body lift or a full drop i.e. 5-6" lift.
Old Nov 9, 2010 | 03:42 PM
oktain's Avatar
Or a solid axle swap... which if you plan on wheeling this thing hard would be awesome.
Old Nov 9, 2010 | 07:21 PM
abig84's Avatar
yeah the s10s actually disengage in the middle of the axle not like the fullsize. slap a dana 44 under there then you can get some manual hubs. funny thing is i just came in from swapping out manual hubs on my s10. i threw that ifs stuff out years ago
Old Nov 10, 2010 | 08:05 AM
nismo_2005's Avatar
i was just thinking about it cause i put some manual hubs on my brothers rodeo when he had it. he has the tbars up a good bit but it was pretty much street only and he never had a cv issue. and yeah i want to go sfa but not for a while. i have a xj for the real wheeling. I really just wanted a way to disco the shafts to save wear on the street.
patterson
Jun 2, 2011 06:47 AM
mafiaboy01
Apr 12, 2011 09:58 PM
educky
Mar 22, 2011 09:18 AM
oisinirish
Feb 14, 2011 12:52 PM
pbrubaker12
Jan 28, 2010 09:57 PM
