maxed outTorsion bars
Old Apr 23, 2008 | 05:39 PM
ryno's Avatar
ryno is an unknown quantity at this point
Default maxed outTorsion bars
So. i finally got under my blazer today to crank up the t-bars a,lil bit. And im confused. THe passn rubs a lil bit so i was going to crank it up so it wouldnt, but.... once i was under there i noticed that the passnger side is maxed out! and it still sits lower than the driver side( the driver side looks to have never been touched) I have never done anything like this on this car. So is that normal? What is the problem. THanks!
Old Apr 23, 2008 | 08:09 PM
TripleBlackBlazer's Avatar
Default RE: maxed outTorsion bars
I had to level mine out as well but it's not maxed out. Sounds like you have a sagging torsion bar on one side. If it's bothering you it will need to be replaced just like a sagging leaf or coil spring.
Old Apr 23, 2008 | 08:14 PM
WolfPack's Avatar
Might also want to check the shock up front. If that shock is blown, all the weight is on the bar, when normally the weight is shared between shock/bar. But it sounds like it's probably just the bar since someone's already tried to fix it (bolt all the way in).
W9370291
Lifting Tech
Jan 16, 2013 01:34 PM
Kemp
Jan 20, 2010 11:36 PM
stevenf
Lifting Tech
May 9, 2008 11:38 PM
02 Vortech
Headers, Intake, & Exhaust
Jun 30, 2005 06:42 PM
beeneeb
Dec 7, 2004 05:10 AM
