Moog or.. NO MOOG control arms
Old Nov 7, 2016 | 09:21 PM
cdtek101's Avatar
cdtek101 is on a distinguished road
Default Moog or.. NO MOOG control arms
Well hell I was about to order Moog R Series control arms with
bushings/ball joints- Now...not so sure.
L Upper: RK620172
R Upper: RK620173
L Lower: RK620300
R Lower: RK620464
Then I read bad reviews on:;
The lowers - sway bar tabs breaking, or no abs mount tabs/holes.
Have not seen any bad stuff on uppers yet,
**anyone have bad experience on uppers ?
Suggestions on alternate control arm brand.. ???
Wondering if I should keep lower arms and just replace ball joint and
bushings on lowers ???
Old Nov 8, 2016 | 12:31 AM
Rusty Nuts's Avatar
Most members wind up buying the control arm and replacing the R series ball joint with a "Problem Solver" upgrade offered by Moog. I'm with you looking for an alternative. All the aftermarket tubular control arms applications are for either lifted $x$'s or lowered 2 wd. Vehicles modified so much the factory control arms have the wrong dimensions. Anybody know where to find tubular control arms for stock 4x4 that uses factory ball joints and bushings?
Last edited by Rusty Nuts; Nov 8, 2016 at 12:33 AM. Reason: Accidentally hit shift, seems to fit so I left it
Old Nov 8, 2016 | 06:30 AM
Impact's Avatar
Impact is on a distinguished road
L Upper: RK620172
R Upper: RK620173
L Lower: RK620300
R Lower: RK620464
I have had no problems with the uppers so far. If I was doing it again I would order the MOOG problem solver control arms. They are a little more expensive but they also have the ball joints that can be greased.
Old Nov 8, 2016 | 07:23 PM
cdtek101's Avatar
I hear ya there....I just got off phone with GM and they
want 300.00 ea GM upper control arm,
and for lower they suggested I get from Car-Quest or O'Reilly
So I am on the hunt doing a cross reference on manufactures and orig gm numbers based on my Vin# for my 1999 4wd LT 4door:
Upper Left / Right - Orig OEM # 15661507 / 15661508
Lower Left / Right - Orig OEM # 15777767 / 15777768
Bill
Old Nov 9, 2016 | 03:02 AM
Rusty Nuts's Avatar
I've found dorman
Upper left / right # 520-139 / 520-140
Lower left / right # 520-141 / 520-142
Old Nov 9, 2016 | 06:39 AM
newguy's Avatar
I've found dorman
Better change the balljoints while their out
Old Nov 9, 2016 | 08:44 AM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
I've put moog upper and lower control arms on two of mine without any problems. The uppers I ordered with the greasable ball joints and the lowers were cheaper to swap in the problem solver ball joints myself. One was a 98, the other a 99...
Old Nov 9, 2016 | 08:11 PM
cdtek101's Avatar
I've found dorman
Ok Rusty Nuts; This is what I came up with as the
way I am thinking about going:
***All have greasable ball joints -Fits 4wd (mine anyway)***
CMAS CB90157 Arm w/ Ball Joint Left Upper; $65.79
CMAS CB90158 Arm w/ Ball Joint Right Upper; $65.79
MEVOTECH CMS501160 Supreme Right Lower; $97.79
MEVOTECH CMS501159 Supreme Left Lower; $97.79
Subtotal $327.16
Now for those real budget minded I found this kit of 4 arms;
193.00 / ( 204.00 shipped to Vegas )
http://www.discountbodyparts.com/det...15-05-PLK.html
Old Dec 16, 2016 | 06:32 PM
cdtek101's Avatar
Finally got my Driver / Passenger Upper / Lower Control
arms... Shocks and new torsion bar mounts installed today.
So with all new Tie rods / Pitman arm and Idler arm
that completes my front end suspension back
to new as I can get it.
Attached Thumbnails Moog or.. NO MOOG control arms-u1.jpg   Moog or.. NO MOOG control arms-u2.jpg
002blazerdude
Lifting Tech
Oct 27, 2010 09:43 AM
Yooper
Jul 26, 2009 03:01 PM
kankoon52
Lifting Tech
Dec 27, 2007 03:30 PM
garry2000blazer
Nov 16, 2007 07:05 PM
mudsliner
Suspension Tech
May 12, 2007 06:08 PM
