my 4x4 has gone crazy!!! HELP!!!
Old Apr 5, 2007 | 10:13 PM
dgreene00017's Avatar
dgreene00017 is an unknown quantity at this point
Default my 4x4 has gone crazy!!! HELP!!!
I have a 2000 s-10 blazer 4 door 4x4. a few months ago my service 4wd light started to come on every few times i drove the truck. It would come onand stay on until you shut off the engine. then things started to get wierd, when I would start the truck in the morning the 4-lo button would flash and if I shifted through nuetral the truck would slam into 4-lo. If i was paying attention and saw the light flash, i could wait and it would time out and stay in 2wd. when it shifted itself into 4wd I would have to play with the buttons for a while to get it to shift back into 2wd. after a while it quit shifting into 4lo and started shifting to 4hi by itself, now it has quit completly. i am wondeering if anyone has any idea what could cause this and Im also wondering if it is possible to change this particular tranfer case into a manual shift. thank you for your time and ideas!!
Old Apr 14, 2007 | 12:34 AM
Ian McBride's Avatar
Ian McBride is an unknown quantity at this point
Default RE: my 4x4 has gone crazy!!! HELP!!!
I had the same thing happen on my '01. It got to the point where the switch was going nuts even when the truck was off. It killed the battery a few times - I had to pull the fuse to stop it.
Unfortunately, I can't help you with an answer, but I feel your pain.
Old Apr 14, 2007 | 12:55 AM
speeddemon560's Avatar
speeddemon560 is an unknown quantity at this point
From what I've heard, to replace the motor that shifts it into 4wd is about $500. It's definitely not worth it. There is another device that is a lot cheaper that gives you full control of the 4wd and lets you shift into it a lot easier. I do not know what it's called though, someone else will tell you,
Old Apr 14, 2007 | 04:03 AM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Wasn't there a recall on that?
my2k2zx2
Nov 27, 2011 07:09 PM
ecitko89
Oct 29, 2011 09:10 PM
Chaba
May 23, 2010 12:52 PM
pilgrim
Engine & Internal
19
Jul 20, 2007 11:36 PM
