Need help : 4WD issue .
Old Aug 14, 2013 | 04:15 PM
French ChevyBoy's Avatar
French ChevyBoy is an unknown quantity at this point
Default Need help : 4WD issue .
2000 Blazer , 4 doors , 4x4 , 4,3l V6, Automatic .
My Blazer is equiped with the 4 buttons 4WD system with RPO NP8 meaning : 2Hi , 4WD auto (Autotrac) , 4Hi , 4Lo .
When in 2Hi, lamp of the button is solid
When pushing 4WD auto button, lamp is flashing continuesly . No small noise of the shaft engagement .
When pushing 4Hi button same thing than for The 4WD auto.
When pushing 4Lo button lamp is flashing and stay flashing even if there is the loud " klang of the 4Lo engaging but I don't have the feeling that I am in 4lo if I take off the car . When pushing back the 2WD button I hear the "Klang of the disengagement of the transfert case.
Concerning the others positions , when I push back the 2Hi button , the 2 Hi lamp flash 1 or 2 times before becoming solid (as usual).
I have checked the vacum lines in the engine compartment and no pipe seems to be leaking .
Before changing any part (transfert case switch, buttons , actuator, vacum electrovalve, transfert case motor, 4wd electronic module ....) I would appreciate your help in the diagnostic and in a check-list indicating me the good schredule for points to investigate .
Thanks in advance .
Serge.
Old Aug 16, 2013 | 07:20 AM
No "specialist" with any idea ?
Old Aug 16, 2013 | 07:35 AM
spittybays
Guest
Posts: n/a
Like you said before you start buying parts you will need to take it to someone with a capable scanner to read the 4x4 codes.
The free guys will not do. Well worth the money.
Old Aug 16, 2013 | 03:56 PM
I am in France and the only one shop in my area with a capable scanner for GM/USA cars is close for holydays ...... In addition they use the TechII only if you let the car ask for repair , not for a diagnostic before repair ................
Old Aug 29, 2013 | 01:34 AM
csifmh's Avatar
csifmh is on a distinguished road
Check the pins on the TCCM for corrosion.
parks336
Dec 1, 2023 12:34 PM
2001 ZR2
Jan 16, 2010 12:39 PM
extreme
Jan 5, 2010 07:29 AM
maximashift
Nov 17, 2009 09:36 AM
maximashift
Nov 17, 2009 09:33 AM
