Need more camber adjustment
Old Aug 2, 2018 | 10:00 AM
Dannyn01's Avatar
Dannyn01 is on a distinguished road
Default Need more camber adjustment
I need more camber adjustment on my 04 Blazer ZR2. Is there anywhere I can get Cam Bolts with more adjustment?
Old Aug 2, 2018 | 07:18 PM
chevyriders's Avatar
Why do you need more camber adjustment? Torsion bars cranked?
I don't think there are cam bolts with more adjustment
Old Aug 3, 2018 | 06:41 AM
Dannyn01's Avatar
i went to get an alignment done since I had just replaced upper and lower control arms and my camber is maxed out, and still is at -2 to -3 degrees. Yes torsion bars are cranked. I see RockAuto sells a +- 2.5* cam bolt kit but I don’t know the specs of the oem onesz
Old Aug 3, 2018 | 08:23 PM
I would look into upgraded upper control arms. If you do get the kit I might keep an eye on your CV axles. They could start going earlier then anticipated.
Old Aug 3, 2018 | 11:11 PM
This is exactly why lift kits like the RC kit come with replacement upped control arms, to correct the camber issues associated with adding more angle to the front suspension geometry. I put about an inch of lift on the front of mine by adjusting the t-bars, any more and the alignment shop can't get the camber to straighten out. Took us about 4 adjustment and alignment attempts to find the sweet spot lol but yeah, maxing out the torsion bars on factory suspension components, camber issues is just the first of many problems you're going to have...
Dkarll88
Dec 10, 2018 04:18 PM
95blazerlt
Mar 8, 2014 05:40 PM
Jase1979
Jun 21, 2012 06:00 PM
99bblazer99
Lifting Tech
May 21, 2012 07:00 PM
tomborsari
Lifting Tech
Feb 2, 2011 03:25 PM
