No vacuum at actuator
Old Mar 22, 2011 | 04:02 PM
cutthroatxxx's Avatar
cutthroatxxx is on a distinguished road
Default No vacuum at actuator
Well like the lost says I have no vacuum at the actuator.I haven't been able to get my truck into 4x4 its a 2000 blazer.I replaced the switch checked the actuator its self&the t case is fine.Today I pulled the vacuum off of the actuator&had someone engage the 4x4&iy wont pull any vacuum any ideas please?
Old Mar 22, 2011 | 04:29 PM
So you cannot pull a vacuum on the actuator yourself? If so, then the actuator is torn and needs to be replaced. If you are not getting vacuum to the actuator, but are getting vacuum at the t-case switch, then you have a problem with the vacuum line running from the switch to the actuator.
Old Mar 22, 2011 | 04:41 PM
The vacuum line that goes to the actuator isn't pulling any vacuum&when I pull the lines off of the switch only 1 of the three pulls vacuum.
Old Mar 22, 2011 | 07:38 PM
Ok so this is gonna make me sound pretty stupie I'm sure but...one of the hose to the switch which I thought went to the actuator broke when I tugged on it so did the one on the actuator.Now I'm not sure if these are the same ones are not.Also on the passenger side right before&above the cat there's aY Shaped fitting for the vac lines&one of them only have a small part of hose left on so I'm not sure of It coulda been a part that broke off,or where it goes.I also noticed the other day there is a piece of hose coming off the top of tue tranny close to the tcase?????thought maybe a vent but there's no filter.
Old Mar 23, 2011 | 09:54 AM
*Thread Closed - Double Post* - Please do not post the same question (or similar problem) in multiple forum sections. Double posting is prohibited by the rules of the forum.
markrd
May 8, 2009 01:39 PM
toofancy83
Dec 11, 2008 11:23 AM
TheJuicer
Oct 16, 2008 10:59 PM
watsonracingteam
Aug 25, 2008 04:48 PM
rooster
Feb 18, 2007 07:16 PM
