Noise in 2hi only
Hey guys needs some advice. I have a 97 4x4 blazer and it just started making a noise in 2hi only. Sounds like a card in a bike spoke in the right front. If you switch to 4hi or 4lo the noise goes away, it doesn't matter if its in gear or not. I have had the truck sense about 50,000mi and the 4 wheel drive is almost never used (wife's car). I just sold it to my dad and now it decides it wants to fall apart. Any help would be appreciated.
Thanks
Dan
Thanks
Dan
Sounds like the engagement cable for the front diff is sticking and causing the collar to interfere with the passenger side output shaft.
is this something that can be fixed without tearing into the diff?
Search around. There are quite a few posts on this. It may be solved by simply lubricating the engagement cable.
Thanks again for the help. I will check it out and post what i find.
Irish07
10-31-2012 06:04 PM
BlazinBlazerZR2
06-03-2009 05:22 PM
Alterac
08-25-2008 08:48 PM
