Noise coming from front end... please help
Old Jan 18, 2006 | 08:58 PM
20Blazer00's Avatar
Default RE: Noise coming from front end... please help
If you want to make sure just rotate the front tires to the rear and rear to the front. That will tell you if it is related to the tires or not. If the noise is still there then it maybe wheel bearing or some other component that is related to that area.... front axle connection to the hub???? just not sure until you lift the front tire and check for bearing tightness...
Old Jan 18, 2006 | 08:59 PM
The reason why I did not suggest the tire rotation method is because tire imbalances are normally felt through the steering column more than the chassis. Wheel bearing problems on the other hand are typically felt through the chassis before the steering column.
Old Jan 18, 2006 | 09:11 PM
mdhokenson's Avatar
mdhokenson is an unknown quantity at this point
Sounds like the same problem I am having and I am sure that it is my bearing. FYI - Advance Auto has a Dynapak Hub/Bearing assembly for $136 on their website. That's the best deal I have been able to find.
Old Jan 18, 2006 | 10:04 PM
user 1016's Avatar
user 1016 has a spectacular aura aboutuser 1016 has a spectacular aura about
I got one for 145 up here in the north woods...front bearing...paid 70 dollars to get it installed at my local tire shop...(don't have the means to change it myself)
Old Jan 20, 2006 | 12:50 PM
Hanr3's Avatar
An improperly worn tire will also cause vibrations and noise at certain speeds. Run your hands around the tire. Do you feel high/low spots? Do you feel sharp edges? Do you see high/low spots?
Most alignment shops will do a free front end inspection to help pin point where the problem lies. Get the free estimate and post up what they find.
If it was a grinding noise, then I would say its your wheel bearing. What your describing sounds more like a tire out of round.
Old Mar 28, 2007 | 06:07 PM
gizwilly's Avatar
gizwilly is an unknown quantity at this point
ORIGINAL: swartlkk
Can you feel the vibration through the steering wheel or through the seat?
Wheel bearings can be checked fairly easily by jacking up the suspect corner and putting your hands at 12 & 6 o'clock and pull out at the top while you push in at the bottom, then push in at the top and pull out at the bottom. If the wheel moves, your wheel bearing is bad.
The thing with this problem that leads me away from an out of balance wheel is that it goes away when the suspension rises over a bump, relieving pressure off of the wheel, but I have to wait to hear back from the two of them about where they are feeling the vibration through.
I'm chasing a noise that sounds similar. I jacked the Blazer (95 4dr,4wd) up and did the 12-6 push/pull. Both sides have no play at all, near as I can tell. However, when I try a 3-9 push/pull I do get a bit of play. I'm assuming that wouldn't be a bearing, or even the source of my noise, but I'm wondering that's considered normal or if it's something else I need to pay some attention to?
Thanks!
Old Mar 28, 2007 | 08:01 PM
blazerlt01's Avatar
blazerlt01 is an unknown quantity at this point
hm it sounds like a wheel bearing just starting to go,and ifit isthese arepricey.take it too a tire shop. i know the shops by me ie(ntb,sears) do a free front end check to make sure everything is legit goodluck
Elishia Norris
May 18, 2013 09:50 PM
ely0569
Nov 16, 2012 06:50 AM
ZR2Daddy01
Apr 30, 2010 10:42 PM
Chrismacster
Apr 2, 2009 06:57 PM
kaejr
Jan 16, 2008 08:32 AM
