noise when turning
Old Apr 18, 2013 | 06:02 AM
swanman35's Avatar
swanman35 is on a distinguished road
Default noise when turning
99 2 door 4 wheel drive. When I turn right I hear a moaning noise. Sometimes when I turn right and it's doing it if I give it gas it will stop. The only thing I have changed out dealing with this sort of stuff since I've owned it were the lower ball joints. I cant really pinpoint whether it's coming from the front or rear
Old Apr 18, 2013 | 06:22 AM
coolasice's Avatar
coolasice will become famous soon enough
when you turn right does it go away? if so probably wheel bearings
Old Apr 18, 2013 | 08:40 AM
tibby's Avatar
Default .
When you turn it all the way? I know it sounds stupid, but low power steering fluid makes a moaning.
Old Apr 18, 2013 | 07:20 PM
swanman35's Avatar
It's not the power steering. I checkef that. It moans when I turn right, but if I accelerate while turning it goes away. I have a code with something to do with the left speed sensor I think. That it?
Old Apr 18, 2013 | 08:17 PM
rexazz2's Avatar
speed sensor is mounted in the bearing hub assembly
Old Apr 18, 2013 | 08:28 PM
swanman35's Avatar
So would that be correct? Turning right would shift the weight over causing thr left side to make that noise?
Old Apr 18, 2013 | 09:35 PM
Each hub assembly has 2 sets of ball bearings, side by side. If a bearing is starting to fail, when the bearing is loaded, it makes noise. When you turn right, the left outer and right inner sets of bearings are loaded, and the left inner and right outer are unloaded. On a left turn, the opposite happens. In the early stages of failure it can be difficult to determine where the noise is coming from. Best to use a stethoscope. After they're worn, you can usualy see/feel looseness when you jack it up and wiggle the tire.
Old Apr 19, 2013 | 11:02 AM
swanman35's Avatar
Thank you.I Will check today
Old Aug 30, 2013 | 01:40 PM
porkfriedrice's Avatar
porkfriedrice is on a distinguished road
When a hub assembly is failing, is the noise kind of a high pitched whine? When I am making left turns I get a noise like that from what seems to be the right side of the truck. Braking doesn't make the noise change, and it's not a "scraping" sound, more like a high pitched "hum"? If that makes any sense. With the truck jacked up I tried spinning the wheel by hand to see if there was a noise, but there wasn't. Also checked to make sure that the brake dust shield wasn't scraping the rotor, but it seemed to have good clearance. Bad hub assembly sound right in this case?
Also, if I do replace the assemblies, is Raybestos a good brand to use? I know Timken is the preferred brand, but was hoping the Raybestos would be a slightly cheaper alternative.
Old Sep 5, 2013 | 03:11 AM
Anyone have any comment on my previous post? I didn't want to start a new thread, should I though? Kind of a quick and easy question.
vankuen
Mar 24, 2008 09:24 AM
Brian J. Lesko
Feb 18, 2008 11:18 AM
S10Blazer
Nov 9, 2007 08:08 PM
southpaw2_4
Aug 2, 2007 11:09 AM
cmblackburn
Apr 11, 2007 10:30 PM
