Is there play in the tire on that side? Jack that side up and grab the sides of the tire and wiggle back and forth and check for play. It may be bad or it may just need tightening
Not normal, there should never be vertical movement in the joint. If it's 2WD the center link needs replacement. If it's 4WD the pitman arm needs replacement.
