Odd Vibration in the front end.
Old May 3, 2014 | 04:37 PM
lockwoodjace's Avatar
lockwoodjace is on a distinguished road
Default Odd Vibration in the front end.
I have a 2000 Blazer 2wd and the other day out of the blue it started having a vibration or a clicking type of feeling out of the front end. I check the wheel bearings and usual suspects and all is fine. It only really happens when I get above 35 mph. It does not get worse the faster you go so I have really no idea what it could be. I tightened things I could and greased what needed it but to no avail. It sends the vibration or clicking feeling up into the steering wheel. I hope someone can advise what to check for because its driving me nuts.
Old Jul 15, 2014 | 03:15 PM
fletch125's Avatar
fletch125 is an unknown quantity at this point
Get your tires rotated and balanced. Tire balancing along with irregular tire wear do some weird things. Does it click when turning? Also check for movement in the centerlink and idler arm. I had a similar vibration and it ended up being that whoever replaced the idler arm before me didnt use lock washers and the dang thing was hanging off the frame. Doubt it would be the same for you but always start with the tires!!!
wGraves
Oct 28, 2009 06:50 PM
rllamarca
Jul 20, 2009 10:58 AM
mikeinwi
Apr 28, 2009 01:57 AM
SanfordBlazer
Feb 27, 2009 07:49 PM
miso
13
Jan 2, 2007 10:20 AM
