Parking Brake Linkage Frozen
Old Dec 30, 2016 | 09:08 AM
Electechab's Avatar
Electechab is on a distinguished road
Default Parking Brake Linkage Frozen
I have a 2001 Blazer with four wheel disc brakes. I recently replaced the rear end due to a locked up differential. The parking brake linkage at both hubs is locked up due to rust. Are new parts available for this? Thanks for any help. Also, I am having trouble getting the universal joint out of the driveshaft. Is it possible that it is secured by dowel pins? It looks like there are dowel pins through it and I am having no luck trying to drive out the universal joint with a hammer and drift. Thanks again.
Old Dec 30, 2016 | 06:00 PM
Rusty Nuts's Avatar
The factory U joint caps are held on with injected plastic that has to be heated with a torch and cooked out. Propane is hot enough and it expands out the hole where you see dowel pins. This clears out the groove for the clips that hold the new one.
I just replaced my parking brake hardware with a kit from oreillys last october.
xderkax
Jan 14, 2010 11:38 PM
mccague36
Dec 6, 2008 09:38 PM
mccague36
Mar 1, 2008 08:05 PM
SmokeU
Dec 29, 2007 09:44 AM
bat119
Dec 1, 2006 04:39 PM
