Pinion bearing
Old Mar 17, 2017 | 11:30 PM
kfro's Avatar
kfro is on a distinguished road
Default Pinion bearing
So I changed the ujoints in my 2000 blazer a few months ago and when I did them I noticed the pinion shaft had a fair bit of play. Blazers been parked for a while and I just dug it out and put a new tires on it and doing the shocks and some front end work on it getting it all fixed up for a nice street legal kidder and hunting truck and want to get this bearing fixed to. Did some reading and found out there's an inner and outer bearing And the outer can be changed from the front but to do the inner requires going from the back does anyone have a step by step thing to help me out in changing this is it possible it's only the outer bearing and how would I tell?
Old Mar 19, 2017 | 09:46 AM
Rusty Nuts's Avatar
You're going to want to pull the whole thing apart. If the outer bearing had excessive play for any amount of time, the inner bearing took too much force. It's easier to change the races with access from the back and it lets you inspect everything else. Timken bearings and seals with new lube will ensure you get in and back out of wherever you hunt. Some you tube videos can take you through gm 10 bolt differential much faster than reading a description. If yours is a zr2, specify 8.625" or 8.5" ring.
Old Mar 24, 2017 | 09:34 PM
kfro's Avatar
What size is the ring gear in a non zr2
Old Mar 24, 2017 | 09:46 PM
Rusty Nuts's Avatar
7.625 inches
Old Mar 25, 2017 | 09:46 AM
kfro's Avatar
Watched a couple YouTube videos thing I have an understanding on what to do. What kind of special tools do I need and anything to look out for while doing this?
Old Mar 25, 2017 | 12:06 PM
kfro's Avatar
How easy would it be to make it a posinrear end what would I need?
snuffy
Sep 21, 2016 08:51 PM
burning_soul07
Feb 7, 2011 08:54 PM
383snowman
Oct 11, 2010 01:06 PM
alamantia
Jan 5, 2010 09:37 AM
chvygirl84
Nov 22, 2008 03:03 PM
