Pitman arm
Old Dec 18, 2009 | 06:30 PM
cts258's Avatar
cts258 is on a distinguished road
Default Pitman arm
how do you change the Pitman Arm on a 89 s10 blazer 4x4
Old Dec 18, 2009 | 06:59 PM
Remove the nut. Put the appropriate pitman arm puller onto the pitman arm and tighten it until the arm pops off.
Old Dec 20, 2009 | 07:33 PM
cts258's Avatar
swartlkk you make it sound so easy..... i heard you cant get the puller on without removing other things
Old Dec 21, 2009 | 12:10 AM
On some you have to unbolt the steering box to move it forward... But that is mechanics 101. If you cannot get access for the proper tools, take things apart until you can.
Old May 6, 2010 | 08:25 PM
Mark_D's Avatar
Mark_D is on a distinguished road
This thread's been dead for a while, but I'll try to revive it with a question about what swartlkk said...
Is a 1998 blazer 4wd 4dr the kind of model on which you have to move the steering box forward? I am replacing the Pitman and Idler and was looking at it today. It looks like it'd be the only way to get a puller on there.
Is it kosher to use a hammer to tap a pitman arm puller to fit between the joints even if it makes the joint start to separate a bit?
Thanks in advance
More importantly, any idea where the bolts for the steering box are? Are they the ones that mount against the left side of the frame, there are 4 or so in a cluster there?
Old May 6, 2010 | 11:54 PM
ohsofly's Avatar
Yes its the 4 on the left outer frame.
As for tapping tools with a hammer, just dont go hitting MY tools with a hammer.
Old May 7, 2010 | 05:38 AM
Mark_D's Avatar
Haha, these aren't my tools either...they're Autozone tools. If I can avoid tapping them into place I will.
Old May 7, 2010 | 02:48 PM
BDS_237's Avatar
BDS_237 is on a distinguished road
The bolts are the three that bolt to the left side of the frame, easily accessible with the tire removed. And don't worry about tapping the puller on, if it starts to separate a little bit, it is only doing what it's supposed to anyway.
Also, FWIW I pulled my box off, and it really was not a big deal. Use a fork splitter to separate the pitman from the steering linkages, then just undo the lines on top & crimp slightly with locking pliers (the name brand escapes me momentarily), and then loosen the bolts in the frame. It is then pretty easy to separate the pitman arm from the box while it is in a vice.
Old May 16, 2010 | 10:49 PM
Mark_D's Avatar
Vise grips?
Ya my pitman arm came off pretty easily...but the box needs to be held steady or you'll never get any torque on it.
Old Jun 25, 2010 | 01:48 AM
michaelross's Avatar
Banned
michaelross is on a distinguished road
I just used the fork splitter to separate the pitman arm just like what you said but I am having a hard time doing it..
