Placing Steering Shaft back in
Old May 25, 2021 | 12:30 PM
Christianbrit95's Avatar
Christianbrit95 is on a distinguished road
Default Placing Steering Shaft back in
Having issues installing the lower intermidiate steering shaft back into the upper intermidiate shaft.
I took out the lower shaft to replace the rag joint and now when reinstalling it in the truck the upper shaft seems too short. I can't seem to pull out the upper shaft anymore than what it is at currently.
Anyone else run into the issue? Want to get advice before I take the whole steering column out to look at it.
Attached Thumbnails Placing Steering Shaft back in-img_20210523_163440.jpg   Placing Steering Shaft back in-img_20210523_163454.jpg   Placing Steering Shaft back in-img_20210523_163446.jpg
Old Jun 1, 2021 | 05:44 PM
Did you get it fixed?
My only suggestion would be to loosen the bolts on the rag joint to allow for some more adjustment and then once the shafts are connected, tighten the bolts again.
Old Jun 18, 2021 | 10:53 AM
One on top is a junk yard part that I added a fresh rag joint on.
Yea I fixed it. Turns out the original shaft was indeed shorter. Truck is much better now.
Christianbrit95
May 23, 2021 03:19 PM
sapper12b
May 6, 2015 09:25 PM
gary h.
Jan 14, 2011 09:57 AM
SniperX13
Mar 16, 2006 09:57 PM
Bigjoey71
Suspension Tech
Jan 3, 2006 12:28 AM
