Pop in front end when shift to reverse
Old Nov 25, 2012 | 01:15 AM
BoDog89's Avatar
BoDog89 is on a distinguished road
Default Pop in front end when shift to reverse
Hi, my blazer makes a pop sound when u initially shift into reverse. Sounds like its coming from the left front, would it be the hubs unlocking? Just wanted to see if anyone had this issue. Thanks
Old Nov 25, 2012 | 03:00 AM
50lb_cat's Avatar
What year? 2 or 4 wheel drive? That is usually a sign of a failing or binding u joint however.
Old Nov 25, 2012 | 01:11 PM
gitch93's Avatar
gitch93 is on a distinguished road
i had the same issue check ur ball lower ball joints as that was my cause of the clunking
Old Nov 25, 2012 | 01:34 PM
BoDog89's Avatar
2002 4 door 4x4. Thanks for the info ill check my universal and ball joints.
Old Nov 25, 2012 | 01:42 PM
gitch93's Avatar
ur welcome let us know if its that
Old Nov 29, 2012 | 12:25 PM
BoDog89's Avatar
Sorry i haven't gotten back about my issue, but i narrowed it down to the front uv joint is going bad (main driveshaft) so will be replacing it in the near future thanks for all the help!
Old Nov 29, 2012 | 07:11 PM
50lb_cat's Avatar
Glad you got it figured out! Be sure not to skimp on quality parts!
stokedboss
34
Sep 4, 2012 07:36 PM
Blade_24k
Jul 23, 2012 08:22 PM
kyjonesy
Feb 25, 2011 08:35 PM
Wxman2000
Aug 11, 2007 03:48 PM
ShadowHawk
Suspension Tech
Feb 11, 2007 09:50 AM
