popping sound in front end
Old May 21, 2013 | 07:29 AM
tate456's Avatar
tate456 is on a distinguished road
Default popping sound in front end
Ok so when taking off from stoplights braking and sometimes turning I get a pop or light clunk from under my 96 blazer ls 4x4 I can not for the life of me figure it out in the past 1500 miles I have replaced balljoints uppers and loweres tie rods inner and outer pitman arm idler arm front shocks swaybar links I dont know whats left to creak or pop
Old May 21, 2013 | 10:12 AM
Stephen Jay's Avatar
Stephen Jay is on a distinguished road
cv axle could be grinding when you turn. i know it happens with a suspension lift if you dont get longer cv's
Old May 21, 2013 | 12:00 PM
Jakeduece's Avatar
Jakeduece is on a distinguished road
Could it be your control arm bushings? Cv axle would be more of a click click click than a pop (at least in my experience). I know that the bushings cause a pop/clunk sound any time the load changes on the front end (turning, accelerating, stopping) so it might be something to check on. If they are dried out and cracked you might want to look at replacing them eventually. Also, make sure the hood bolts/pins are tight (dumb as it sounds, its actually a common issue on these, and when the bolts are loose it sounds like a bad ball joint.) When your truck pops, do you feel it through the steering wheel?
bam_9_9_9
24
Dec 28, 2010 07:58 PM
sschuler
Jan 5, 2009 03:43 AM
therealdeal770
Sep 21, 2007 10:20 PM
Joey P.
Jun 4, 2007 09:33 AM
bob the blazer
Suspension Tech
Jun 16, 2006 10:13 PM
