Possible CV joints
Old Jan 8, 2008 | 12:45 PM
dwellupon's Avatar
dwellupon is an unknown quantity at this point
Default Possible CV joints
I have a 91 S10 blazer and when slowing down it sounds as if the brakes are down to metal and grabbing. I replaced rotors and brake pads to no avail. I think it is the cv joints as one of the boots is busted. If it is the cv joints, how hard are they to change? Thank you for any help.
Old Jan 8, 2008 | 01:48 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
Default RE: Possible CV joints
They arent too bad to change. Pretty reasonably priced too (about $70 a side). In the how too section DCFlux did a write up on how to do it for a second generation blazer. The first generations are extremely similiar in design and most of the instructions will be the same. Read through that and if you have any questions post away and we are glad to help.
Old Jan 8, 2008 | 01:52 PM
dwellupon's Avatar
Thank you i saw the post on the 2nd Gen and didn't know how close it was.
Old Jan 8, 2008 | 02:36 PM
dwellupon's Avatar
Sorry, quick question does anyone know about how long it takes?
Old Jan 8, 2008 | 03:36 PM
RCars2's Avatar
Should take about a full day to do both sides. Unfortuneatly i speak from experience on that. That was a long hot summer day, LOL.
Old Jan 11, 2008 | 01:45 PM
dwellupon's Avatar
I asked a fellow blazer owner i work with to look at that i work with. He suggested the wheel bearings. Problem is when looking all i can find is the assembly. Is it possible to buy the bearing and having it pressed in?
Old Jan 11, 2008 | 01:49 PM
The wheel bearing / hub assembly is only available as an assembly.
Old Jan 11, 2008 | 01:51 PM
dwellupon's Avatar
Thank you i appreciate the quick response.
Old Jan 15, 2008 | 07:30 AM
dwellupon's Avatar
I replaced the right front cv axle. While this part was pretty much shot.....Its still making a grinding, scraping, clunk noise when the truck is in motion . Any Ideas?
Old Jan 15, 2008 | 11:22 AM
aris_unlimited's Avatar
aris_unlimited is an unknown quantity at this point
Have you checked to see if anything is rubbing on the tires/wheels/rims when you are driving. That could be a possible explanation.
jingerage
Dec 17, 2013 02:35 PM
LoLoS10Blazer87
Suspension Tech
Sep 19, 2008 07:43 PM
TDQ
Suspension Tech
Jan 9, 2006 01:50 AM
alexbtango15
Suspension Tech
Jan 7, 2006 01:06 AM
hdlogistics
Suspension Tech
Dec 2, 2005 10:53 AM
