Power Steering Hose Replacement Advice needed
Old Jan 29, 2024 | 02:49 PM
Default Power Steering Hose Replacement Advice needed
Hi all,
I'm in the middle of replacing my power steering gear and was going to replace the power steering hoses while I was at it. Well, I am stuck with how to get the pressure hose off from the back of the pump.
Can anyone give advice?
I did find one old post on this, https://blazerforum.com/forum/2nd-ge...ng-leak-95045/, but it wasn't too helpful without pics.
As you can see, I did get my flare-nut wrench on the nut, but I don't have enough room to swing it to loosen it. In one direction the wrench hits the return tube, in the other it hits the frame. I tried getting it from below with the wrench hanging at the 6 o'clock position, but I could not get any force on it to swing as when it is in that position, it is pointing down at the crossmember.
(BTW it's a 5/8" = 16mm nut)
If the wrench were shorter I might work, but before I start cutting up a wrench or go try to buy one, I thought I'd ask here first for any hints or advice.
View from above
View from below
View through wheel well.
Second view through wheel well.
Old Jan 31, 2024 | 10:44 PM
In case anyone finds this, here is how I got the pressure hose off.
I had to buy a flare-nut crow-foot set. I used the 5/8" one with a 3/8" breaker-bar. I tried using a regular 3/8" rachet wrench with a 2" extension, but I could not get it on in a way that was useful.
Because of limited space, I had to use a 6" adjustable wrench to get the nut off. I stubby wrench would have been perfect.
A hint is to not forget the new o-rings for the hoses and that the old o-rings came out with the old hoses.
View from below and looking towards rear.
View from above.
Old Mar 8, 2024 | 01:03 PM
Stovey's Avatar
Stovey will become famous soon enoughStovey will become famous soon enough
There is definitely not a lot of room to work. Still, I was able to get at the pressure hose with a regular flare wrench. If I recall correctly, it is most accessible from below the vehicle. And it may help to to turn the wheels left or right to move the pitman arm out of the way.
The crowfoot set will come in handy for connecting the hoses to the steering gear.
emarie
Oct 25, 2017 12:30 PM
midnightbluS10
Jul 29, 2017 07:36 AM
Evobeast
Feb 16, 2012 04:33 AM
Jesster
Oct 4, 2011 11:31 AM
sbmotoracer
Dec 4, 2007 08:03 PM
