rear axle flip
Old Sep 29, 2009 | 12:05 PM
truckman6740's Avatar
truckman6740 is on a distinguished road
Default rear axle flip
i have a 97 s-10 blazer i was interested in doing the rear axle flip. i was wondering how difficult it is and how much, if any, it will lift it? and what the best thing to about rear leaf springs arching the opposit way would be?
Old Sep 29, 2009 | 04:02 PM
abig84's Avatar
basically just have to grind off the spring perches and put new ones on top of the axle.. other things too. gonna need longer shocks, maybe. longer brake lines and the center pin will have to be placed into the bottom of the spring or just grind the bolt down so it looks like a pin.
Old Sep 29, 2009 | 04:06 PM
NVANZEE's Avatar
You should be able to get the weld on perches from superlift. It will give you about 5in of lift. It will be fairly easy to do.
What do you mean about the springs arching the opposite way? You dont do anything with the springs
Old Sep 29, 2009 | 11:30 PM
over the years the springs have started to arch the opposite way
Old Sep 29, 2009 | 11:44 PM
does anyone know how big of a lift i would need to clear 36.5" tires i have know clue and i want to get the rite lift the first time
Old Sep 30, 2009 | 07:23 AM
NVANZEE's Avatar
that would be a huge lift. It would have to be all custom made. Would require a solid front axle in the front. I have 9in of lift for 33s. You would also have to do a lot of fender trimming.
Old Sep 30, 2009 | 08:00 AM
abig84's Avatar
Yea. You can possibly run them with a 8inch if you cut the body up. I'm doing a spring over in the back with a 4inch block and my 33s would rub in front under heavy flex
Old Sep 30, 2009 | 07:38 PM
NVANZEE's Avatar
with my 9in of lift my 33s still rub with full compression
Old Sep 30, 2009 | 09:54 PM
my S10 pickup has 8 inches of lift and i have 44/10.50/15s on it and it works just fine
Old Sep 30, 2009 | 10:02 PM
NVANZEE's Avatar
im assuming you had to cut the fenders a lot.
95blazerlt
Jan 16, 2010 12:44 AM
Vahomboy
Jun 25, 2009 11:24 AM
fla_blazer4x4
Lifting Tech
Mar 16, 2008 12:54 PM
deadcujo
Jan 8, 2008 08:34 AM
Jharper
Nov 29, 2007 09:43 PM
