Rear Axle Removal
Old Jul 17, 2007 | 06:18 PM
INeedHelp's Avatar
INeedHelp is an unknown quantity at this point
Default Rear Axle Removal
Well, I need to know how to get the rear axle off. Ive been trying, and decided to turn to you guys for help.
Thanks so much in advance
-Me
Old Jul 17, 2007 | 06:23 PM
Default RE: Rear Axle Removal
Besides the typical, unbolt the springs, unbolt the driveshaft, and disconnect the brake lines and parking brake cables, what else do you need to know?
Maybe we can help with suggestions on how to fix the actual problem that you are experiencing. What exactly is going on. Also, what are ya workin' on? Year? Model? Options?
Old Jul 17, 2007 | 06:26 PM
INeedHelp's Avatar
S-10 Blazer 1996. I Need to get the driver's side rear axle off. I tried pulling it out, it there a clip holing it in? Do i have to take the rear end apart?
Old Jul 17, 2007 | 06:31 PM
Ah ok. Yes, you will need to remove the diff cover... Now the procedure changes a bit if you have the G80 RPO code (glove box label) which is the gov-loc rear diff locker as opposed to an open diff. Once that is known, I can walk you through the whole process.
Old Jul 17, 2007 | 06:39 PM
INeedHelp's Avatar
I figured it out, There is a C-Clip in the back.
Look at - http://www.autozone.com/images/cds/g...3d8018c466.gif
Thanks for your help!!
Old Jul 17, 2007 | 07:06 PM
Yeah, for the open diff, it is as simple as removing the cover, removing the pinion shaft and the spider gears, then pushing in on the axles and removing the c-clips. Then the axle will come right out.
With the G80 locker, there is quite a bit more parts involved.
hcii
19
Apr 19, 2013 04:20 PM
99blazerguy
Nov 10, 2010 04:28 PM
fowellkris
Mar 7, 2010 04:45 PM
jsoluna
Jan 26, 2010 08:20 PM
missu
Jan 25, 2007 05:53 PM
