rear axle swap
Sorry if im already asking a question that's been answered im on my phone
I have recently blew up my rear gu6 axle in my 2003 blazer. This is the 2nd one in 2 years, is there anyway of getting a bigger axle like out of a 1500 or so? I have 33s and the stock gears so im sure that isn't helping. :( Thanks in advance |
Why don't you find a ZR2 axle to swap in. They are an 8.5 I believe. Or the best way IMO would be to swap in an 8.8 out of an explorer and have the hubs redrilled to 5x4.75.
Would I have to change drive shafts or anything? Im just trying to get out of breaking axles so often.
You may have to change the rear u joint and possibly figure out the ebrake but those should be pretty simple to figure out since a ton of others have done it.
But the splines will line up? I took out my e brake cables anyway I just wanna get like an upgrade for the rear so a zr2 or ford explorer rear end. Im thinking ill do the zr2 swap so do I have to change shock mounts for that?
Yeah they are both "almost" bolt in axles. Keep in mind also the Z axle is 2"(I think some correct me if I'm wrong) wider so it will push your rear end out a bit. What do you have for a lift? If its still the IFS the Z axle will make your rear wheels even with the fronts.
I know El_Beautor and Okiedoak20 are both running Z axles you may want to hit them up for more info:) |
Yea I have the ifs I wish I had a solid front axle cause the front chews through cvs and steering components.
So I have the gu6 3.42s I think that's what it is, what do I do in matching the front? Or do I change the front gears also with these swaps? I really appreciate the help! |
The only difference was the rear u joint. It is different and I found a conversion u joint and problem solved, also had to change the u joint straps but if u pull the axle get the straps with it.will save a lot of time later. The rear wheel spacing is wider. Thats helps a lot with the front/rear width thing.
Originally Posted by 2003_CHEVY_BLAZER
(Post 589532)
What I did was, I found a jimmy with 3.73 gears and took both axles. Sold some parts got most my money back then had the carcass towed out
Got $300 for that, then installed both axles in my Envoy. Axles ended up being free but still had to do some work to get them |
| All times are GMT -5. The time now is 10:27 PM. |
