Rear axle woes
Old Nov 29, 2009 | 01:18 PM
Alacorn101's Avatar
Alacorn101 is on a distinguished road
Smile Rear axle woes
I have a 2000 S10 Blazer. The rear axle bearing went bad necesitating a new rear end. As money is not near as plentiful as I might have hoped I removed a rear from a junkyard as opposed to purchasing, or rebuilding the existing rear. As the new to me rear has drum brakes I am in the middle of swapping over all of my disc brake goodness from my bad rear to the good rear. The problem I have is that while the original rear has an open dif, the new to me rear has the G80 CODE, GOV-LOC option. I dont know how to remove the axles from this style differential. Mainly I'm not sure how to drop the shaft pin in order to remove the C clips so that I may remove the axles. I would really appreciate any input from anyone who has removed or knows how to remove axles from the same style locked rear I'm currently involved in. Thanks in advance
Old Nov 29, 2009 | 03:04 PM
It has been a long while since I had a G80 rear opened up, but from what I recall, it has the same cross bolt & pin arrangement, but the c-clips only come out one side.
Old Nov 29, 2009 | 04:17 PM
Alacorn101's Avatar
Hmm, well I removed the cross bolt and the pin drops only about half an inch, its acting as its being held in by something. I guess i can use a bigger hammer, however the 2lb sledge should've done it. I guess if that doesn't work I can remove the Loc? Ill post back if the big hammer works, or if i destroy it Any further davice welcomed thanks :>
Old Nov 29, 2009 | 06:07 PM
If it comes out far enough so that you can see the hole where the retaining bolt goes in, put the bolt through the hole and use that as a handle to pull it free. Nothing should need a hammer to facilitate removal.
blajeans
Jan 9, 2013 12:58 PM
jmaynard
Jul 12, 2011 01:03 PM
sledneck16
Oct 21, 2006 12:25 AM
robert8868
Aug 18, 2006 12:22 PM
dundydotcom
Jul 8, 2006 05:07 PM
