rear diff questions?
Old Sep 22, 2013 | 03:11 PM
toyhauler1283's Avatar
toyhauler1283 is on a distinguished road
Default rear diff questions?
I found a website that lists all the RPO codes and after I went threw all the codes I know my blazer has the 3.42 gears.( not the ones I was hoping for) I still have no idea what size it is. Whether it is a 7.5 or 8.5 rear any info on how to tell would be great
Old Sep 22, 2013 | 03:29 PM
rexmburns's Avatar
Super Moderator
What's the specs on your truck? Chances are its a 7.5 unless you have a ZR2
Old Sep 22, 2013 | 05:36 PM
Its a 97 4 door 4x4 and does not have the g80 another bummer
Old Sep 22, 2013 | 09:00 PM
Twip's Avatar
also the axle tubes for the 7.5 are the same size from end to end. the axle tubes for the 8.5 get larger just before the pumpkin.
Attached Thumbnails rear diff questions?-gm10-bolt-75.jpg   rear diff questions?-gm10-bolt-85.jpg
Old Sep 22, 2013 | 09:08 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
The chances of 4 door having a g80 rearend are as lucky that hair will regrow on the top of my head or my psychotic neighbor will move sometime soon.
Old Sep 22, 2013 | 09:44 PM
rexmburns's Avatar
Super Moderator
I have 3:73s and a G80
Old Sep 22, 2013 | 09:48 PM
Yeah but did the vehicle come with them gears or did you install them?
Old Sep 22, 2013 | 10:05 PM
rexmburns's Avatar
Super Moderator
Surprisingly they are factory! I even managed to get the full skidplate option
Old Sep 23, 2013 | 12:20 AM
Thogert's Avatar
I had all 3 of those options on my 4 door as well. Thing was a beast for what it was.
Old Sep 23, 2013 | 10:24 AM
El_Beautor's Avatar
The only way to get the 8.5 10 bolt in a 4 door Blazer is an axle swap from a ZR2. If you go this route, it's pretty easy to do the rear axle. I did mine in about 2 hours by myself in the driveway. Swaping the front diff to keep matching gears is a lot more painful, but possible to do with normal hand tools. My truck came with 3.42 gears too, and I swapped in a ZR2 axle to get the 3.73 gears, wider stance, and the G80 locker.
