Rear differential assembly interchangeable
Old Jan 30, 2022 | 04:53 PM
Travis L's Avatar
Travis L is on a distinguished road
Default Rear differential assembly interchangeable
I have a 2002 Oldsmobile bravada I need a new differential assembly I'm looking to see what other vehicles are interchangeable any help?
Old Feb 3, 2022 | 05:21 PM
mr.vls's Avatar
The differential should be the same in Chevy Blazers and GMC Jimmy's. Except for ZR2 which has a longer wheel base. The important item is to match the gear ratio to your existing gear ratio. The gear ration is listed in the RPO codes. (Should be in the glove box) GU1 Axle Rear 2.41 GU2 Axle Rear 2.73 GU3 Axle Rear 2.93 GU4 Axle Rear 3.08 GU5 Axle Rear 3.23 GU6 Axle Rear 3.42 GU7 Axle Rear 2.77 GU8 Axle Rear 3.90 GU9 Axle Rear 3.91. Also look to see if you have G80 Locking Rear Diff.
Tgramberg7
Jun 26, 2020 07:48 PM
99_Bravada
Jan 29, 2016 10:45 PM
kickme005
Sep 1, 2010 08:06 PM
BusaJoe
Dec 14, 2009 10:04 AM
Bad Ramer Jamer
Sep 19, 2008 05:43 PM
