Will 97 Bravada disc brake rear fit my 95 Bazer
Old Sep 19, 2008 | 02:58 PM
Bad Ramer Jamer's Avatar
Bad Ramer Jamer is an unknown quantity at this point
Default Will 97 Bravada disc brake rear fit my 95 Bazer
They both are 4x4. The Bravada has rear discs. This car looks like it rolled in off the showroom.
When I jacked up my rear, there was a whole lot of slop, and noise going on. What would it cost to rebuild my rear. I'm not sure that it needs it even, I just thought it would be good to have the rear discs off the Bravada. I can get it for $175,,or $200 if I have the cut it out. What all would I need to do the conversion. Thanks.
Old Sep 19, 2008 | 04:57 PM
Default RE: Will 97 Bravada disc brake rear fit my 95 Bazer
If you do not have rear disk brakes, then you may have some fun getting the parking brakes to work. You will also need a 4 wheel disk brake proportioning valve and/or master cylinder to get everything working properly...
Old Sep 19, 2008 | 05:43 PM
TripleBlackBlazer's Avatar
Also, check for gear ratios. A lot of Bravadas have 3.73`s, but not all of them. You will obviously want to match the gears you have in your Blazer.
Mark_D
Apr 29, 2011 11:40 PM
hcii
Nov 3, 2010 08:30 AM
quinn1991
Tires and Wheels
Dec 28, 2008 02:41 AM
dimmuborgir6nik6
Jan 31, 2008 01:35 AM
mlon01
Sep 7, 2007 11:48 AM
