Rear differential problem 94 s10 4x4
Old Jun 5, 2020 | 05:57 PM
BigDad503's Avatar
BigDad503 is on a distinguished road
Hey guys,wanted to post an update real quick..I finally made it home.Had to trailer the Blazer back on a U-Haul,but at least I got er home.This may sound like an irrational question, but let's say a person removed the rear pinion shaft,would that render the Blazer inoperable,or would it still operate as a roller,given the vehicle has front wheel drive?I'm determined to get the necessary parts and fix this truck,but unfortunately it's my only vehicle at the moment.I can imagine the perplexed expression on a person's face while reading this.I know how it sounds,but I will fix this truck.
Old Jun 5, 2020 | 06:00 PM
I've actually done similar. The problem is that you need oil in the rear end to lube the axle bearings, so you would need to plug the pinion hole, as well as the hole in the transfer case where the driveshaft goes. If you can do that, it should work. Temporarily, at least.
Old Jun 9, 2020 | 01:46 AM
BigDad503's Avatar
I'll definitely remember that.I only need to drive it about 5 miles or so to a local parts yard,and have been given permission by the owner to do the work there.Thank you again for your advice.I will see what works in the morning.
Old Jun 9, 2020 | 08:24 AM
Good luck. I hope it works out for you. Keep us posted.
LannyL81
Mar 5, 2018 05:48 AM
Green93
Oct 22, 2013 11:14 PM
J Mac
Jan 14, 2013 06:10 AM
mrkevinmjr
Jun 12, 2011 08:26 PM
Chevyguy032
Feb 14, 2007 12:00 AM
