rear end issues!
Old Sep 5, 2007 | 09:41 PM
20blazerXtreme02's Avatar
20blazerXtreme02 is an unknown quantity at this point
Default rear end issues!
my rear end went out in my blazer about a month ago and i put a new rear end in not the same one though and i know i should of but with this new rear end just recently there started a vibration from about 45-85 and it does it even worse it seems when your slowing down. and when i put into gear theres a clunk but no other noise after that.. could someone please help me?!
Old Sep 5, 2007 | 09:54 PM
hillbillyinOhio's Avatar
Default RE: rear end issues!
please do not create multiple posts on the same topic. When someone has an answer, they will post up.
Old Sep 5, 2007 | 09:57 PM
99 Blazer 4x4's Avatar
99 Blazer 4x4 is an unknown quantity at this point
My post is right below your I to am experiencing the same clunk when shifting into forwardor reverse and I get a clunking type noise when shift into second especially when it has set over night after ithas warmed up it gets a little better but still noticable. I check and changeallfluids like clock work. I was told it could be the rear u-joint as they oftenfail more than the front but I checked them and they were fine. Hope somebody can help us with this and also myother listed in 4x4 2 hi switch acting weird problem.
Old Sep 5, 2007 | 10:39 PM
sorry it didnt show up in the other one so i figured i didnt click the post thing.. my bad.. and my blazer is a 2wd
Old Nov 15, 2007 | 02:45 PM
bossvette's Avatar
bossvette is an unknown quantity at this point
I have the same problem in my 89 a bad "clunk" when putting in gear or changing directions I have changed the U-joints and had the rear cover off the R&P look fine and the "Slack" is somewhere in the carrier/posi unit . Is there a simple fix?
Old Nov 15, 2007 | 11:44 PM
Chevy Lover's Avatar
I'm getting confused with 3 guys posting their problems in the same thread!
A vibration at speed could be caused by u-joints, driveshaft out of balance, loose pinion gear or wheel balance.
A clunk when going forward to reverse or park to drive could be worn u-joints, backlash in the diff (slack between the ring and pinion gears), slack in the transmission or transfer case.
doktornasty
Nov 3, 2013 03:12 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
brino1
Feb 25, 2011 08:05 PM
cbash1979
Apr 3, 2008 08:39 PM
johnnyb
Nov 6, 2007 02:41 PM
