rear end noise
Old Dec 6, 2007 | 05:11 PM
01ice's Avatar
01ice is an unknown quantity at this point
Default rear end noise
I have a 01 Blazer 4x4 4 door, my problem is when I take off from a stop and stomp on gas it seams like the back really drops and that something sounds like it is hitting,kind of a clunk,it almost sounds like the rearend gets to much traction and the truck can,t keep up.at 1st i thought the spare was hitting but does the same if i take it out.Could this maybe weak shocks? or is this the way the lsd works.any help would be apprieciated.thanks
Old Dec 6, 2007 | 09:02 PM
JB97's Avatar
JB97 is an unknown quantity at this point
Default RE: rear end noise
Is the rear end sagging at all? I would check the ride height of your vehiclewith the manufactuers and compare your measurement. Also, jounce the rear of the vehicle. If the vehicle goes down, comes back and stops, your good. Any more play means worn rear suspension.
Old Dec 16, 2007 | 09:07 PM
moe_23's Avatar
moe_23 is an unknown quantity at this point
I just had the same problem and today my rear end is blown, everytime I step on the gas its revs to about 2-2500 and then you hear the rear end gears finally catching and it makes a extremely loud "clunk" andjumps forward.I would suggest stop driving your car and opening up the diff or checking the u joints for the driveshaft, when I take a look at my car I will post an update
doktornasty
Nov 3, 2013 03:12 AM
brino1
Feb 25, 2011 08:05 PM
bthom331
Nov 20, 2009 10:38 AM
Chrismacster
Apr 2, 2009 06:57 PM
isfumpire
May 17, 2006 05:24 PM
