Rear End Question...?
Does this video explain it pretty good? Why is he making marks and counting the threads?
https://youtu.be/HNkGdByzyjI
Doing the job that way he does not even verify proper gear pattern by pulling the cover.
You are suppose to install a new crush sleeve then torque it properly to ensure the preload on the pinion bearings are correct. then you should pull the rear cover and use marking compound to verify the ring and pinion mesh correctly.
And is this the right seal ? http://www.oreillyauto.com/detail/ma...ttr_10039=Rear
And how many oz of gear oil does the rear end take ? It's 80/90 oil right ?
I know you suggested to take it to a shop but I simply can't afford it with no job or money, so my cheapest route is to do it myself. I start school for automotive tech on the 23rd of this month and this is my only means of transportation.
The chances of you doing something wrong and causing the rear diff to fail are very high if you dont know what you are doing. I have seen these things fail and put a pinion through the cast iron case.
Or just go to a junkyard and find another 4x4 differential with the correct gear ratio and swap the entire assembly. might be cheaper than trying to fix what you have especially if the one you have is already making noise.
I understand its expensive, but if you cant afford to fix it correctly and you rely on this truck daily i would just keep the fluid full as long as it is not leaking very bad. then fix it properly when you can.
David M. Chamberlain II
06-01-2017 07:17 PM
brino1
02-25-2011 08:05 PM
