95 zr2 rear axle swap with 96 standard blazer rear end
Old Jun 1, 2017 | 02:07 PM
David M. Chamberlain II's Avatar
David M. Chamberlain II is on a distinguished road
Default 95 zr2 rear axle swap with 96 standard blazer rear end
Greetings, so I've a 95 zr2 blazer, the rear end started making a loud click/squeak. Called gm parts with my vin and they said my rear end is 7.58 ring gear and 373 ratio. Found a rear end off a 96 stock blazer, from what I've read it will work and I'll need 2" wheel spacers to even out the back wheeles with the front...am I on the right path?
Old Jun 1, 2017 | 04:03 PM
El_Beautor's Avatar
The ZR2 axle is 3" or so wider than the stock 4x4 axle. If you're going to sort that out with spacers, I'd suggest 1.5" spacers. You'll probably also need to replace the brake lines as I'm pretty sure the ZR2 lines will be too long for the non-ZR2 axle.
Old Jun 1, 2017 | 05:16 PM
newguy's Avatar
Thought zr2 s had 8.5 rear ends
Old Jun 1, 2017 | 05:46 PM
AJBert's Avatar
3.9" wider to be a bit more exact and 8.5/8.625" on the rear end. Not sure exactly what the OP is driving but sure doesn't sound like a ZR2. Are you going just by a set of stickers or what the previous owner told you?
Old Jun 1, 2017 | 07:17 PM
the guy that sold it to me turned out to be a liar. In going thru paperwork in the glovebox, last year the truck had 247,xxx when I bought it in April it had 149,xxx. I'm beginning to think it's not a zr2.
mmikemitchell
Mar 14, 2011 10:56 PM
rodono
Feb 27, 2011 08:07 PM
brino1
Feb 25, 2011 08:05 PM
karatekid90
Feb 10, 2010 01:17 AM
supercoop
Tires and Wheels
Oct 13, 2008 10:38 PM
