Rear wheel bearings
Old Jan 14, 2009 | 12:51 AM
chrisblaze's Avatar
chrisblaze is an unknown quantity at this point
Default Rear wheel bearings
Wondering is someone can guide me in the right direction on rear wheel bearings? I have been reading a lot of post on here now for about 3 hours!! I got the front hub & bearings understood & know what I need, but rear I'm confused with what I need! Can I just purchase 2 bearings? 1999 S10 zr2 blazer 4wd.
Once again I appreciate the feed back!
Chris
Old Jan 14, 2009 | 01:33 AM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
Default RE: Rear wheel bearings
Unless your rear axle has problems you won't need to worry about the rear end. Also are you sure you need front hubs they are to expensive just to change because you can.
Old Jan 14, 2009 | 01:48 AM
chrisblaze's Avatar
I know the front drivers side ABS connection was disconnected by past owner, he didn't tie it up good and it wore down! Can I just purchase the ABS connection?
Old Jan 14, 2009 | 06:35 AM
Is there a reason why you are looking to replace all of these components?
I believe that the ABS sensor is available separately. Check out RockAuto.com or your favorite autoparts store.
dpmeeks
Sep 27, 2013 06:37 AM
ComputerNerdBD
Aug 30, 2011 10:59 PM
ComputerNerdBD
Tires and Wheels
Mar 5, 2011 05:50 PM
222
Jul 31, 2009 11:20 PM
BlazerBoy
Jul 25, 2005 11:53 AM
