Rebuilding Rear Diff
Old Sep 17, 2009 | 05:54 PM
GeorgeCooper48's Avatar
GeorgeCooper48 is an unknown quantity at this point
Question Rebuilding Rear Diff
Just wondering if anyone has done a rebuild on a rear differential of a 1999 Jimmy or Blazer? I had a spider gear go out so I have a pretty good clunking noise when I take turns and have it parked for now. I do not believe it is the ring and pinion because there is not any noise when going in a straight line. If anybody could give me a heads up as to what I am getting into or things to look out for or any prior experience would be greatly appreciated. Also, I know it is not a universal because I already pulled the drive shaft and check that.
Old Sep 17, 2009 | 06:20 PM
TripleBlackBlazer's Avatar
https://blazerforum.com/forum/steering-suspension-drivetrain-36/rear-axle-shaft-seal-leaking-34623/
As long as you're just taking the carrier out and putting it back in you'll be fine. If you mess with the pinion depth or with the ring gear then you'll have to set backlash and all that detailed stuff.
If/when you take the carrier out, make sure you label the shims on either side and put them back in EXACTLY how they came out.
Old Sep 17, 2009 | 06:46 PM
I only plan on taking out the carrier. Is there any special tools needed? And do you have any information on workin on the carrier itself, such as replacing the spider gears, or is that pretty much just install n go?
Old Sep 17, 2009 | 07:39 PM
The post I linked mentions a slide hammer. This is to get the bearings out.
If you're only putting new spider gears in you don't really need to put new seals and bearings in but you might as well since you have it open.
Lining the spider gears up (with the little cups that go underneath them) with the pinion shaft was a pain for me but I left the carrier in the housing.
Old Sep 19, 2009 | 01:20 PM
dart08's Avatar
dart08 is an unknown quantity at this point
I agree with replacing the rear wheel bearings and seals while doing the spider gears repair. I kept the pinion shaft part way in and replaced one spider at a time. That way both gears don't fall out and you have to hunt for any shims that might have fallen off.
The Slacker
Mar 31, 2008 09:00 PM
AtreyuManiac
Feb 22, 2008 09:37 PM
88s10Blazer
Jun 30, 2006 12:56 AM
jagblazer01
Jun 17, 2006 06:46 AM
Tittlebitties
Jan 4, 2006 07:11 PM
