removing front axles for the summer
Old May 25, 2015 | 09:36 AM
DTS77's Avatar
DTS77 is on a distinguished road
Default removing front axles for the summer
I lifted my blazer and tore a dust boot on the axles, i was wondering if i could remove the axles for the summer and leave them out and when i have the money and need 4x4 ill just put new ones, what are your thoughts and anything a should know going into it. also while doing the lift i couldn't take the axles out because they seem to be seized to the diff assembly pretty good (Nova Scotia salt road for the win)
Old May 25, 2015 | 11:13 AM
Jamaroon's Avatar
The unit bearings NEED the shaft installed or else you will experience a bad failure of the unit bearing. So simply removing the CV shafts is not a good idea. You would need to cut apart the old CV's and put the ends back into the unit bearings, torqued to spec.
Old May 25, 2015 | 11:51 AM
DTS77's Avatar
ok i figured that would be the case, ill end up cutting them, one is clicking pretty bad now so time to do something. thank you for your reply and love your rig
Old May 25, 2015 | 12:27 PM
Jamaroon's Avatar
No problem, and thanks.
You should also put something to cover up the ends of the axle so dirt and debris can't get in there.
Old May 27, 2015 | 12:22 PM
abig84's Avatar
maybe just put grease in there once a month unless you are going off road a lot. there are lots of customers cars who never fix their ripped boots and never have any axle failure
Old May 27, 2015 | 12:26 PM
newguy's Avatar
Did this for a year on my old truck, just pump grease in there every month or so and no problem, for me any way
Old May 28, 2015 | 05:37 AM
DTS77's Avatar
Ya I was doing that, but with the salt on the roads and minor off-roading the drivers side has a nasty click to it, eventually I need to do a complete overhaul on the front end, so I may just deal with the clicking for now and wait till I do that
Old May 28, 2015 | 06:14 AM
newguy's Avatar
Did change mine, not that hard
Old May 28, 2015 | 12:16 PM
DesertStorm's Avatar
mine is doing the same thing and i put grease in it as well... if it breaks then i will just park it until i get the rest of the SAS stuff together.
Old May 29, 2015 | 05:37 AM
DTS77's Avatar
So I did a break service last night to fix my squeaky break and realized what was clicking, come to find out it's just the boot that is making the noise, so gave the joint a healthy dose of grease and was happily on my way. Can these cv's be taken apart and anyone have a thread on how it's done? Thanks
roycet4
Sep 21, 2010 07:28 PM
thewickedk5
Aug 8, 2010 01:36 PM
218persuader
23
Oct 9, 2009 07:24 AM
blkblazer
Mar 10, 2009 05:34 PM
webbyj883
Suspension Tech
Sep 9, 2005 02:15 PM
