Replaced Transfer case motor.. need help
Old Apr 19, 2014 | 10:44 AM
CursedBlackBlazer's Avatar
CursedBlackBlazer is on a distinguished road
Default Replaced Transfer case motor.. need help
I have a 2001 blazer ls. I just replaced the transfer case motor yesterday. I put everything back the way i took it out and now the 4wd service light is illuminated. The blazer stays in a neutral state shifting between all pnrdl gears. Need some suggestions please of a possible fix.
Old Apr 19, 2014 | 12:35 PM
EZEARL's Avatar
EZEARL is on a distinguished road
Are you sure you've got the t/c shaft fulling engaged in the encoder motor?
Old Apr 19, 2014 | 03:10 PM
how can i tell if the shaft is fully engaged into the motor?
Old Apr 19, 2014 | 04:17 PM
EZEARL's Avatar
Motor should EASILY fit flush all the way around against the t/c surface. I know when I replaced mine I ended up taking the encoder apart to reposition the gear for the t/c because,and I'm just guessing,it was tested by just connecting it but not on the t/c which put the gear all the way to one side. If the gear and shaft aren't engaged there will be a small gap.
Old Apr 19, 2014 | 04:42 PM
got it fixed, thanks for the help.
LesMyer
38
Jan 9, 2020 11:45 AM
Flyfishen
Jun 18, 2019 11:22 AM
greatwhite
May 22, 2013 08:43 PM
int3414
Aug 27, 2012 07:58 PM
Greg Olson
May 11, 2012 07:03 PM
